I've just updated to arm-none-eabi 11.2-2022.02 and when trying to launch GDB I get an error message that python27.dll can't be found.
Installed from the official installer "gcc-arm-11.2-2022.02-mingw-w64-i686-arm-none-eabi.exe" on a Windows 10 machine.
Do I have to install Python 2.7?! Seems a bit off..
Any help / suggestions are appreciated!
Thanks,
Even after installing Python 2.7 and adding it to the path, it still can run GBD.
Any official answer about this please?
In Arm GNU Toolchain 11.2-2022.02, GDB has enabled Python, and therefore running GDB requires a working installation of Python.
On a Windows machine, this requires Python 2.7.
That works. Thanks!
Now, considering that Python 2.7 was EOL in 2020-01-01, any plans to update it to a newer version?I mean, having to have installed v2.7 can be a problem, even for security...
Thank you for the feedback. The Python2 EOL is a known limitation in this release.
