I am attempting to install and build gcc-arm-none-eabi source on a PocketBeagle SBC. The PB has an embedded Arm A8 in the TI OSD3358 SiP. The ultimate goal is to be able to build CircuitPython on the PB. I have installed all the prerequisite packages for the Debian "Buster" IoT operating system, version 10.3 armhf architecture. During the build-prerequisites.sh script, the install fails at Task [II-0] /i686-w64-mingw32/zlib/ line 267 with error message;
"Compiler error reporting is too harsh for ./configure (perhaps remove -Werror).** ./configure aborting."
Do you know what that means? How do I fix it? Thanks in advance.
--Cliff
