I just installed gcc-arm-11.2-2022.02-darwin-x86_64-arm-none-eabi.pkg on a Mac with Apple Silicon.Trying to compile anything, always results in this error: internal compiler error: Illegal instruction: 4I don't have any of these issues with the previous release of the toolchain (gcc-arm-none-eabi-10.3-2021.10-mac.pkg).I also tried version 11.2-2022.02 on an Intel based Mac, and there are no compiler errors, as can be seen below.
❯ system_profiler SPHardwareDataType SPSoftwareDataType Hardware: Hardware Overview: Model Name: MacBook Air Model Identifier: MacBookAir10,1 Chip: Apple M1 Total Number of Cores: 8 (4 performance and 4 efficiency) Memory: 8 GB System Firmware Version: 7429.81.3 OS Loader Version: 7429.81.3 Activation Lock Status: Disabled Software: System Software Overview: System Version: macOS 12.2.1 (21D62) Kernel Version: Darwin 21.3.0 Boot Volume: Macintosh HD Boot Mode: Normal Computer Name: derek’s MacBook Air User Name: derek (derek) Secure Virtual Memory: Enabled System Integrity Protection: Enabled Time since boot: 6:07 ❯ arm-none-eabi-gcc --version arm-none-eabi-gcc (GNU Toolchain for the Arm Architecture 11.2-2022.02 (arm-11.14)) 11.2.1 20220111 Copyright (C) 2021 Free Software Foundation, Inc. This is free software; see the source for copying conditions. There is NO warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. ❯ bat main.c ───────┬──────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────── │ File: main.c │ Size: 53 B ───────┼──────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────── 1 │ int main(void) 2 │ { 3 │ float var = 1.f; 4 │ return 0; 5 │ } ───────┴──────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────── ❯ arm-none-eabi-gcc -mcpu=cortex-m33 -mfpu=fpv5-sp-d16 -mfloat-abi=hard -mabi=aapcs -mthumb -c main.c main.c: In function 'main': main.c:3:5: internal compiler error: Illegal instruction: 4 3 | float var = 1.f; | ^~~~~ Please submit a full bug report, with preprocessed source if appropriate. See <https://bugs.linaro.org/> for instructions. ❯ source .zshrc ~ ❯ arm-none-eabi-gcc --version arm-none-eabi-gcc (GNU Arm Embedded Toolchain 10.3-2021.10) 10.3.1 20210824 (release) Copyright (C) 2020 Free Software Foundation, Inc. This is free software; see the source for copying conditions. There is NO warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. ~ ❯ arm-none-eabi-gcc -mcpu=cortex-m33 -mfpu=fpv5-sp-d16 -mfloat-abi=hard -mabi=aapcs -mthumb -c main.c ~ ❯
➜ ~ system_profiler SPHardwareDataType SPSoftwareDataType Hardware: Hardware Overview: Model Name: MacBook Pro Model Identifier: MacBookPro16,1 Processor Name: 6-Core Intel Core i7 Processor Speed: 2,6 GHz Number of Processors: 1 Total Number of Cores: 6 L2 Cache (per Core): 256 KB L3 Cache: 12 MB Hyper-Threading Technology: Enabled Memory: 16 GB System Firmware Version: 1715.81.2.0.0 (iBridge: 19.16.10744.0.0,0) OS Loader Version: 540.80.2~11 Activation Lock Status: Disabled Software: System Software Overview: System Version: macOS 12.2.1 (21D62) Kernel Version: Darwin 21.3.0 Boot Volume: Macintosh HD Boot Mode: Normal Computer Name: derek’s MacBook Pro User Name: derek (derek) Secure Virtual Memory: Enabled System Integrity Protection: Enabled Time since boot: 1 minute ➜ ~ arm-none-eabi-gcc --version arm-none-eabi-gcc (GNU Toolchain for the Arm Architecture 11.2-2022.02 (arm-11.14)) 11.2.1 20220111 Copyright (C) 2021 Free Software Foundation, Inc. This is free software; see the source for copying conditions. There is NO warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. ➜ ~ bat main.c ───────┬───────────────────────────────────────────────────────────────────────────────────────────────────────────────── │ File: main.c │ Size: 53 B ───────┼───────────────────────────────────────────────────────────────────────────────────────────────────────────────── 1 │ int main(void) 2 │ { 3 │ float var = 1.f; 4 │ return 0; 5 │ } ───────┴───────────────────────────────────────────────────────────────────────────────────────────────────────────────── ➜ ~ arm-none-eabi-gcc -mcpu=cortex-m33 -mfpu=fpv5-sp-d16 -mfloat-abi=hard -mabi=aapcs -mthumb -c main.c ➜ ~
Any idea what might be causing these problems?
Best regards,Derek
