Static variables failing to initialize using libgcc/libstdc++
I am attempting to cross compile from Windows to Linux using gcc-arm-9.2-2019.12-mingw-w64-i686-arm-none-linux-gnueabihf. We are building with static runtime lib using -static-libgcc and -static-libstdc++. Everything builds and appears to run, however, the static variables that should be initialized to a value appear to all still be 0. I assume that the initialization of the crt isn't occurring, but I'm not sure how to fix that. We've been building this same setup on Linux directly with distro provided arm-linux-gnueabihf toolchains without issue in the past. This is our first attempt to build with this toolchain from Windows. Does anyone have experience with something similar?
  • Hi there, thanks for asking a question in the Arm Community. Just to make sure that we can get you the correct answer, I have moved your question to the Compilers and Libraries forum. Many thanks.
  • Perhaps it would be helpful for me to post a version of the linking command. This is cleaned up version of what is being run (names are changed and a lot of .o files are removed to simplify.
    arm-none-linux-gnueabihf-g++.exe -O3 -DNDEBUG -static-libgcc -static-libstdc++ -o myapp first.cpp.o second.cpp.o -LE:/boost/stage/lib -LE:/linux/lib -Wl,-rpath,E:/dev/boost/stage/lib:E:/dev/linux/lib libLibrary.a -lboost_chrono -lboost_coroutine -lboost_context -lboost_date_time -lboost_filesystem -lboost_iostreams -lboost_program_options -lboost_regex -lboost_serialization -lboost_signals -lboost_system -lboost_thread -lboost_wserialization -lboost_log -lcrypto -lssl -ldns_sd -lavahi-client -lavahi-common -ldbus-1 -lsystemd -llzma -lselinux -llz4 -lgcrypt -lpcre -lgpg-error -lpthread -ludev -lstdc++fs -ldl -lgpiod -lm
    At the point the only thought I've had is to see if directly adding crtbegin.o and friends are needed with this setup, but as I haven't had to do that in the past, I'm really not sure what might be going on.
  • Does the application initialize properly if it is compiled on Linux, but with the Arm provided toolchain instead of the distro-provided toolchain?
    You may want to apply verbosity options (-v) to the compilation and linking commands, to see the complete command that gcc/g++ executes.
  • Apologies. I thought the difference was just between the toolchains, but there was a very subtle difference in the link order between how the two versions were being built that lead to an initialization order conflict.
