void function1(void){... // Optimized at O1 (from armcc -O1)}#pragma push#pragma O3void function2(void){... // Optimized at O3}#pragma popvoid function3(void){... // Optimized at O1 (from armcc -O1)}
How do we find an alternative way?
Hello
I have moved your question to the Compilers and Libraries forum.
Oli from the Community team
More info here. See the row for "#pragma Onum" : "armclang does not support changing optimization options within a file. Instead these must be set on a per-file basis using command-line options."
armclang
disappointed. that means I cannot set different Onum for a section in a source file. It's a backslide . ARM Complier V5. is better and stronger.
I want to set different levels of optimization for different sections In a C source file
I found some error on O1 in Complier 6.16 for a whole C source , but I need some section O1. the other part use O0.
disappointed. that means I cannot set different Onum for a section in a source file?
The single C source file can be broken up into multiple C files, so that the Onum option can be applied at a file level.
earth-boy111 said:I found some error on O1 in Complier 6.16 for a whole C source
If your program displays different logical behaviour when compiling with different optimization options, then the program is likely to have a bug.
