I'm using Arm DS-5 Eclipse with the Arm Compiler 6 Toolchain. In NIOS II, it is allowed to open files using fopen function to access the device list and it works because the NIOS II Eclispe uses the Newlib C library. However, in Arm DS-5, the Newlib C library is not built in yet, so my question is how to get the fopen function called to the device list. Do I have to add the Newlib C library to the workspace or I have to write my own alternative functions ??
The Arm C library uses semihosting for the implementation of such functions.https://developer.arm.com/documentation/dui0471/m/what-is-semihosting-/what-is-semihosting-?lang=en
I found the below reference, which explains that you need to implement these yourself for newlibhttps://wiki.segger.com/Semihosting#Semihosting_with_GCC_and_newlib
