Hi all -
Beginner's question here: I downloaded and unzipped the ARM toolchain. In the directory C:\gcc-arm-none-eabi-10.3-2021.07-win32\gcc-arm-none-eabi-10.3-2021.07\bin, I have what appear to be the correct files, though they have rather "decorated" names:
(I hope you can read that well enough to understand what I'm saying.)
I've added this directory to my path variable. When I run make, though, I get errors like:
c:\Program Files\AmbiqSuite-R2.5.1\boards\apollo3p_evb\examples\hello_world\gcc>makeThe system cannot find the path specified.CC not found on PATH (arm-none-eabi-gcc).The system cannot find the path specified.LD not found on PATH (arm-none-eabi-ld).The system cannot find the path specified.CP not found on PATH (arm-none-eabi-objcopy).The system cannot find the path specified.OD not found on PATH (arm-none-eabi-objdump).The system cannot find the path specified.AR not found on PATH (arm-none-eabi-ar).The system cannot find the path specified.RD not found on PATH (arm-none-eabi-readelf).The system cannot find the path specified.SIZE not found on PATH (arm-none-eabi-size).The system cannot find the path specified.GCC not found on PATH (arm-none-eabi-gcc).
I couldn't find any documentation for after unzipping the download; am I supposed to rename the files in my directory or something?
Thanks for any guidance...
