Regarding Linux aarch64 calling conventions (ABI)
In the documenttion I've seen, it appears that the first 8 registers x0-x7 are for parameter passing and don't need to be saved.
But this is always vaguely defined so I need to ask:
If function A uses all of x0-x7 and then calls function B, which uses x4-x7 as temporary variables, this will wipe out function A's values. Why would I not need to back up x4-x7, as the documentation suggests?
Thanks.
0
