Simulate ARM7 over Qemu
Hello all, I am a complete beginner in ARM and I have only worked with AVR and Arduino boards before. What I want to do is write a simple C program which will print "Yes" when 1 is entered and "NO" when 2 is entered by the user. Now I have to compile the code using gnu GCC arm toolchain and create a binary patch for executable generated. The patch should work like this: When entered 1 print "NO" and for 2 print "Yes".
1. How do I compile the code using this toolchain
2. How to create and executable file
3. How to create a binary patch which would work as said.
I could not find any proper tutorials to do this on Windows 10 machine. So any tutorial links you can share to solve this will also be appreciated.
Thank you
0
