Gcc/linker problem
I have a project with a folder with sources and other with static libraries compiled by me.
I have no compilation errors but when I debug the code I have a problem, it is all fine until i reach a function inside of which there is a call to another function which jumps to 0x0 address. This functions belongs to a static library. I tested to call the destiny function and I can jump perfectly to this function, but if it is called from the other function the process crashes resulting in a jump in 0x0. I dont know either if it's a problem of the linker script or another problem.
Does Anyone have an idea on what might be going on?
  • Check the access permissions, or security settings of the address of this function. You have not said which CPU you are using... perhaps for example you are trying to call a secure function from non-secure world on a Cortex-M33, or similar situation.
    If it branches specifically to 0x0 that is the reset vector on Cortex-A, but the sp init value on Cortex-M. Perhaps your stack is not set up properly?
  • Thanks for the response.It is a cortex m3 (lpc1769) the first option is discarted, the second option could be because I'm using a linker script from internet, and the stack's part figures like a piece called dummy_stack, I'm going to try change this option and I will inform about this
  • I found the problem, as you said, it was the sp's init value. I solved the issue adding a symbol in the linker script like this in the beginning
    _estack = ORIGIN(RAM) + LENGTH(RAM);
    Then i changed in the startup file the stack pointer included in the vector table and I added before of the table:
    __attribute__((section(".stack"), used)) unsigned *__stack_init = &_estack;
