I am trying to compile a simple test C code which calls a cde function __arm_cx1a.
And always encountered with a ld error: undefined reference to '__builtin_arm_cx1asi'
The version of arm-none-eabi-gcc i am using is 10.2.1(GNU Arm Embedded Toolchain 10-2020-q4-major)
The command is
arm-none-eabi-gcc -mcpu=cortex-m33 test.c -D__ARM_FEATURE_CDE --specs=nosys.specs -mthumb
Anyone know how to work this out?
Thanks.
