I am trying to write a C code with just inline functions so that there would be no access to stack. But I see the compiler is inserting a push instruction at the start of the main. Also, this behaviour is not seen every time. With a slight change in the code sometimes I don't see the push instruction. I would like to know the what is the reason behind this
Target CPU: Cortex M23
Compiler: GCC
Code structure:
#include "interface.h"
int main(void)
unsigned int operation;
operation = <SFR read>; status = check_status(operation); if(status) { return(status); }
Disassembly:
int main(void){ c00069c: b510 push {r4, lr}
<rest of the inline functions>
Header file: interface.h
inline unsigned int check_status(unsigned int oper) __attribute__((always_inline));
<function body>
Automatic variables go on the stack - so, if you don't want the stack to be used, don't create auto variables!
If the rest of the disassembly you didn't show actually uses lr for calling another function, or uses r4, then it's no surprise that they're being pushed. If not, then it might be that optimization is turned off, and that it would be a little more efficient if it was on.
