When I compile an assembler file with Keil, the ame tool says that it is not defining a symbol, I know that it is a Keil configuration problem, but I don't know where to solve the problem, can you help me?
I read the link you sent, I followed your instructions but I still have the compilation problem, I no longer know what to do I have assistance for a year but the technical assistance does not respond.
You seem to be replying to a different thread?
As the title says "8051", I presume you are referring to Keil Ax51?
So this should be in the Keil forum - a moderator can move it.
I do not understand what it means .
