I'm attempting to migrate a project to either Arm Compiler 5 or Arm Compiler 6 ( preferably Arm Compiler 5 ) in DS-5 from Visual Studio 2019. The project in question contains files that are organized in a few subdirectory layers, though, none of the path lengths are anywhere near the Windows 10 MAX_PATH length. When I attempt to build my project, several files will not build unless I move them to a directory very close to the DS-5 project, within at least one or two directories. The error message I receive is "armcc command with no effect" in Compiler 5 and "no input files" in Compiler 6. The files do indeed exist in the locations that the compiler is attempting to look ( unless I don't understand something about the way to compiler looks for a file ).
I'm not sure what is causing this issue. I'm open to trying anything to get it resolved.
My setup is:
DS-5 version 5.29.2
Arm Compiler 5 version 5.06u6
Arm compiler 6 version 6.10.1
Windows 10
