I was trying to add RO data size to a FW image header.
In header.inc file I had done
DCD ||Image$$TEXT$$ZI$$Limit|| - ||Image$$TEXT$$Base||
It generated error - Error: A1142E: Subtractive relocations not supported for ELF format output
I see there is an error information - developer.arm.com/.../list-of-the-armasm-error-and-warning-messages--------------------------------------------------------------------------------------------------------------
This can occur when subtracting symbols that are in different areas, for example:
IMPORT sym1IMPORT sym2DCD (sym2 - sym1)--------------------------------------------------------------------------------------------------------------
However If i individually insert the ||Image$$TEXT$$ZI$$Limit|| and ||Image$$TEXT$$Base|| into header.inc, there is no issue.Both of them are plain integers and should be ok to subtract. And both the addresses are like base address and then end adresss, subtracting which the size will be calculatedIs there any workaround to / correct way of doing that?
Hi Anupam_on
Are you still looking for help with this question, or did you find the solution?
Could not find it yet. Any help is appreciated
