I am not sure if this is the right forum, if not, please tell me what forum will be more appropriate.
I want to use DSP libraries. I use arm-math library. and run this function:
void startFFT (void) { printf("1 \r\n"); arm_cfft_radix4_init_f32(&S, FFT_SIZE, 0, 1); // Initialize the CFFT/CIFFT module, intFlag = 0, doBitReverse = 1// @@@@@@@@@@@@@@@@ need to be added to Init in main area in the ANC code @@@@@@@@@@@ // @@@@@@@@@@@@@@@@@@@@@ need to add sin to "Input" argument @@@@@@@@@@@@@@@@@@@@@ printf("2 \r\n"); arm_cfft_radix4_f32(&S, Input); // Process the data through the CFFT/CIFFT module // @@@@@@@@@@@ Doing FFT on the input, and save it their (?) // print the result of real and imag for checking printf("3 \r\n"); arm_cmplx_mag_f32(Input, Output, FFT_SIZE); // Process the data through the Complex Magniture Module for calculating the magnitude at each bin printf("4 \r\n"); arm_max_f32(Output, FFT_SIZE, &maxValue, &maxIndex); // Calculates maxValue and returns corresponding value printf("5 \r\n"); return;
The MCU printing 1, 2, and 3 lines. but stuck after that (at this function: arm_cmplx_mag_f32(Input, Output, FFT_SIZE); ). I am using Keil, I tried use CubeIDE environment, and it run without problem. Maybe my configurations aren't good?
BTW, if i add a"GNU Extensions" to the compiler, I have a 5 new warnings:
compiling main.c... ..\Inc\arm_math.h(293): warning: #2803-D: unrecognized GCC pragma #pragma GCC diagnostic push ..\Inc\arm_math.h(294): warning: #2803-D: unrecognized GCC pragma #pragma GCC diagnostic ignored "-Wsign-conversion" ..\Inc\arm_math.h(295): warning: #2803-D: unrecognized GCC pragma #pragma GCC diagnostic ignored "-Wconversion" ..\Inc\arm_math.h(296): warning: #2803-D: unrecognized GCC pragma #pragma GCC diagnostic ignored "-Wunused-parameter" ..\Inc\arm_math.h(7146): warning: #2803-D: unrecognized GCC pragma #pragma GCC diagnostic pop ../Src/main.c: 5 warnings, 0 errors compiling stm32l4xx_hal_i2c.c... compiling stm32l4xx_hal_rcc.c... compiling stm32l4xx_hal_dma_ex.c... compiling stm32l4xx_hal_flash_ramfunc.c... compiling stm32l4xx_hal_flash.c... compiling stm32l4xx_hal_exti.c... compiling stm32l4xx_hal_cortex.c... compiling stm32l4xx_hal_pwr.c... compiling stm32l4xx_hal_dma.c... compiling stm32l4xx_hal_gpio.c... compiling stm32l4xx_hal_flash_ex.c... compiling stm32l4xx_hal_pwr_ex.c... compiling stm32l4xx_hal_rcc_ex.c... compiling system_stm32l4xx.c... linking...
those warning leading to those errors:
