Howdy!
I'm using a SEGGER J-Link with Windows 10 and GNU ARM GCC / Eclipse. In my C source code I have this line where I declare a flash based structure (so only reading is possible by regular code -- I have other code that erases and writes it). I wrote a bootloader for an STM32F030 device which occupies ::
8000000 to 8002FFF is bootloader
8003000 to 8003FFF is "calibration storage"
8004000 to 800FFFF is my main application code
So I declared this structure (it's 42 bytes in size)
const cal_t cal_primary __attribute__((__section__(".section_cal_pri")));
this is from my linker script :-
FLASH_PRI_CAL (r) : ORIGIN = 0x08003800, LENGTH = 1k
.cal_flash_section_pri (NOLOAD) : { . = ALIGN(4); __mysection_start1__ = .; *(.section_cal_pri*) __mysection_end1__ = .; } > FLASH_PRI_CAL
However whenever I start a debug session, GDB / Eclipse erases this structure (to zeros) the area of flash corresponding to the "cal_primary" variable. I am not sure how to stop this happening (I tried using NOLOAD in the linker script) The equivalent thing for RAM would be to use the .noinit section,
I dont want this DEBUG flash initialisation to happen because this area contains calibration data I want to keep.
Interestingly the HEX file I build does not have any initialisaition data for 8003800 defined,
BUT GDB is erasing it at debug session start -- how can I stop this?
Thanks, Nick
