HelloI try to add some generalization into the C++ project thus I use std::tuple to hold fields.I'm investigating the difference in assembly code between std::get<1>(myClass.myTuple).read() and myClass.myField.read().myField.read() is compiled as:9A02 ldr r2, [r13, #8]E71F b #0x16a0which is obvious and expected.While std::get<1>(myTuple).read() is compiled as:9B82 ldr r3, [r13, #0x208]695B ldr r3, [r3, #0x14]42AB cmp r3, r5D11B bne #0x1a3cF8BD0210 ldrh.w r0, [r13, #0x210]E761 b #0x1792In theory std::get has to be evaluated in compile-time and the result should be similar in both cases.For what reason do we get this additional comparison?9B82 ldr r3, [r13, #0x208]695B ldr r3, [r3, #0x14]42AB cmp r3, r5D11B bne #0x1a3cI cannot find any situation when the code follows this branch.What can I do to simplify this code?Can I change something in my C++ code to get a result equivalent to direct field access (myField.read())?How can I force the compiler not to generate this additional piece of code?Any help is appreciated./Adam
