Spliting the code in ARM GCC linker script
Hi
I have a project that requires a function to be placed at a particular location in flash (0x15555 to be precise). The issue is that my code is larger than this. When I build now, I get the following error:
ERROR: section NV_CONFIG2 loaded at [00015555,0001558b] overlaps section .text loaded at [00000000,0004a7f3]
Can we modify the linker such that the function is placed first and the code is placed in the remaining region? I am flash-limited in my project so I would not prefer to place the entire code after the said location. Also, manually arranging each file in sections would not be feasible as the code is in development.
0
