I am facing issues with initialization of an object array within the Constructor. I would like to initialize my array using initialization from brace-enclosed lists. But the armcc compiler for some reason, doesn't compile my code nor throw me a warning!
For example, the array would be of "Component" type:
class Component { public: Component(const uint8_t componentValue); private: const uint8_t ComponentValue; };
Next, the "Device" class, would utilize the "Component" in an array.
class Device { public: Device(); private: Component components[3]; };
Now, within the Device.cpp, I try to initialize the array in the default constructor call as:
Device::Device() : components{Component(3),Component(4),Component(5)} {}
I have set my compilation flags to -cpp11. Also, this code compiles on a "arm-none-eabi-g++" compiler.
Why am I not able to compile this on armcc 5.06?
