Dears,
I have been compiling with arm-none-eabi-gcc version 4.9.3 for a while; and everything were just fine with a Cortex-M0 I recently have tried using version 8.3.1 and things are not going as well.
I compiled the exact same code with the released version described earlier.- ...-gcc 4.9.3: Code complies and runs properly;- ...-gcc 8.3.1: Code compiles and seems to not execute on target.
I've been looking in the GCC changelogs and I cannot see any change that could explain the behaviour.
The command line is as follows:
arm-none-eabi-(version) -g -mthumb -mcpu:cortex-m0 -std=c99 (source files) -I (include paths) -L (path to linker script) -T (linker script) -o (target.elf)
Any idea of what could explain the compiler behaviour to change from version 4.9 to 8.3?
Any default option has been changed since 4.9?
I thank you for your help
