Suma M said:Not able to figure out the issue..!!
Go on - it clearly tells you what's wrong:
Error: C9555E: Failed to check out a license.License server system does not support this version of this feature. Feature: mdk_std_compiler5 License path: ;c:\program files\arm\licenses\license.dat; FlexNet Licensing error:-25,147 Check that your license details are correct in the License Management dialog of MDK. Additional information is available at: www.keil.com/.../license_management.htm
and it tells you where to go for help:
If you need further help, provide this complete error report to your supplier or license.support@arm.com
so have you done that?
The license error states that your license expired in July 2017.
Please contact your local sales team to renew. Contact details at the below, I'm not sure where you are basedhttp://www.keil.com/company/contact/Ronan
Ronan Synnott said:The license error states that your license expired in July 2017
right there:
Suma M said:IDE-Version:µVision V5.28.0.0Copyright (C) 2019 ARM Ltd and ARM Germany GmbH. All rights reserved. License Information:Suma MFlex license: MDK Plus 5.28 (Flex) (mdk_plus)Expired: Jul 2017
