ARM GCC Retarget dosen't work in coresight example
I have not seen any axi transfer when I run coresight example helloworld.
And the cpu program counter stopping in some code
I have some questions when I check my IMAGE0.lst file
1 .why printf is branch to putchar instead of printf in coresight example?
2. Is GCC retarget modify _write function?
3. What GCC glibc version recommended to use for coresight example and CPU-R8?
-------------IMAGE0.lst----------------
printf("A");
7d18:  e3a00041  mov r0,  #65  ; 0x41
7d1c:  fa0000a3    blx 7fb0   <putchar>
--------------retarget.c-------------------
void output_char(int c){
    volatile int *tube = 0xfc000000;
    *tube = c;
int _write(int fh, char *buf, int count)  {
int i = 0;
while (i < count){
    output_char(buf[ i++ ]);
I use GCC 8.3.1 20190703 (release gun tool for arm embedded processor 8 2019.q3)  and glibc is 2.14
  • Hi Ben,
    1. printf is optimized to putchar because you're printing only one character. It's much more efficient to call putchar in this case rather than calling printf.
    2. I'm not sure I understand this one. Could you give a bit more detail?
    3. The arm embedded releases are for baremetal toolchains, so no glibc is involved. newlib is the c runtime that is used for these and is included in the package.
    Thanks,
    Tamar
  • Hi Tamar
    Thanks for your reply.
    1. I try to print more characters and it call printf function. thank you
    2. I want to retarget my printf to UART
    The coresight example provide a file retarget.c and include this file to compile.
    I follow user guide to run simulation But it doesn't any transfer
    The expected result is characters will see on AXI port.
    So I'm not sure what I lost to do.
    3. I have error when I run arm-none-eabi-gcc. ->  arm-none-eabi-gcc: /lib64/libc.so.6: version `GLIBC_2.14' not found (required by arm-none-eabi-gcc)
    I download glibc2.14 to install and solve this error.
    Do I use wrong tooling for coresight test?  But our project need to use GCC.
    Thank you!
  • Hi Ben,
    The toolchain is built to support Ubuntu 14.04 and newer, so indeed a minimum of GLIBC 2.14 is required.
    For the UART case did you try to compile the example as is to see if it works?
    Cheers,
    Tamar
  • Hi Tamar
    I try to run the retarget example and it works.
    Then found an issue in our design. Now we solve design's problem.
    Final GCC retarget printf indeed to modify _write function
    Thanks for your help!
  • No problem, I'll mark this as answered then :)
