Optimization difference between C and C++
I  noticed a optimization difference between compiling a simple source code with ARM GCC in C and C++. The C++ version seems to optimize a lot less stack usage.
To demonstrate this problem, I compiled the following code with arm-none-eabi-gcc version gcc-arm-none-eabi-8-2018-q4-major-win32, first only -O2, then with -O2 -x c++ :
Fullscreen
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
#include <stdio.h>
#include <stdint.h>
struct TestStruct
uint32_t field1;
uint32_t field2;
uint32_t field3;
uint32_t field4;
struct TestStruct initStructure(uint32_t f1, uint32_t f2, uint32_t f3, uint32_t f4)
struct TestStruct myStruct;
myStruct.field1 = f1;
myStruct.field2 = f2;
myStruct.field3 = f3;
myStruct.field4 = f4;
printf("Temp Address %lx", &myStruct);
XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
Here are link to demonstrate the problem :
https://godbolt.org/z/PGCp2y Pure C
Line 44, stack usage is
sub sp, sp, #28
https://godbolt.org/z/7XfsQR C++
Line 37, stack usage is
sub sp, sp, #76
Adding multiple calls to the doStuff function in C does not change stack usage, but in C++ it does.
I am curious on why this difference in optimization exists. Is it a bug or is there C++ specification against such optimization ? Or is there an optimization option I am not aware of that would change this behavior ?
Thanks in advance
0
