This query is regarding the time difference the GNU ARM Embedded Toolchain takes to build a system on Windows 10 vs Windows 7.Earlier I was using Windows 7 for compilation of a large bare metal system(around 5000 files) and it took around 2.5 hours to complete the build.Now, I migrated to Windows 10 and it takes around 12 hours to complete the same build.Executables used:1) arm-none-eabi-gcc.exe2) arm-none-eabi-as.exe3) arm-none-eabi-ld.exeIt would be really great if you could direct me in the right direction to resolve this issue and if there's anyway to reduce the build time.
