Architecture: Cortex-M0
Toolchain: gcc-arm-none-eabi-6-2017-q2-update, gcc-arm-none-eabi-8-2018-q4-major
In an attempt to mitigate the possibility of stack overflow I would like to reset the stack pointer after entering a function that will never return. There are two cases in my code where this occurs, main() and a shutdown() ISR that saves data to flash and enters deep sleep. I use LTO to make the code fit, so main() ends up being quite a large function that requires allocating part of the stack for local variables. My first attempt was to use the "noreturn" attribute combined with a call to __builtin_unreachable(), but that does not change the generated assembly in any way. I then created an inline assembly function to reset the stack pointer to the last SRAM address:
inline __attribute__((always_inline)) void NO_RETURN (void) { extern const uint32_t __stack_top__; asm volatile ("ldr r3, %[stack_top]\n" "mov sp, r3\n" : /* no outputs */ : [stack_top] "m" (__stack_top__) : /* no clobbers */ ); }
I then call this at the very beginning of main and the shutdown ISR:
int main (void) { NO_RETURN(); /* rest of the code here... */ } void shutdown_immediate (void) { NO_RETURN(); }
This generates seemingly correct code for the ISR:
00007f60 <shutdown_immediate>: 7f60: b570 push {r4, r5, r6, lr} 7f62: 4b21 ldr r3, [pc, #132] ; (7fe8 <shutdown_immediate+0x88>) 7f64: 681b ldr r3, [r3, #0] ; Why is this instruction inserted by the compiler? 7f66: 469d mov sp, r3 ; ... 7fe8: 00202000 eoreq r2, r0, r0 ; last SRAM address
For main however the "mov sp, r3" happens after stack is allocated for local variables etc.. This will fail once main starts branching.
00001180 <main>: 1180: b5f0 push {r4, r5, r6, r7, lr} 1182: 4be7 ldr r3, [pc, #924] ; (1520 <main+0x3a0>) 1184: b097 sub sp, #92 ; 0x5c ; This SUB must be _after_ 0x1188! 1186: 681b ldr r3, [r3, #0] 1188: 469d mov sp, r3 ; ... 1520: 00202000 eoreq r2, r0, r0 ; Last SRAM address
Does anyone have any tricks for how this can be done correctly? I could always create a second variant of the NO_RETURN() function which takes a stack allocation value as an argument, compile, disassemble, compile again and insert the required "sub sp, #nn" after the "mov sp, r3", but that is a messy solution.
Bonus question: Why does the compiler generate the "ldr r3, [r3, #0]" instruction? "Load r3 into r3 with zero offset" sounds like a nop?
