gator module cross-compile failed
host linux version 4.4.154 target:firefly rk3399 (arm64)
I cross-compile gator on host use
make -C /home/emel/arm-project/linux-kernel/kernel M=`pwd` ARCH=arm64 CROSS_COMPILE=/opt/gcc-linaro-4.9-2016.02-x86_64_aarch64-linux-gnu/bin/aarch64-linux-gnu- GATOR_WITH_MALI_SUPPORT=MALI_MIDGARD MALI_DIR_MIDGARD=/home/emel/arm-project/linux-kernel/kernel/drivers/gpu/arm/midgard/ modules
the errors follow:
make: Entering directory '/home/emel/arm-project/linux-kernel/kernel'
CC [M] /home/emel/arm-project/gator/driver/gator_main.o
In file included from /home/emel/arm-project/gator/driver/gator_main.c:270:0:
/home/emel/arm-project/gator/driver/gator_backtrace.c: In function 'report_trace':
/home/emel/arm-project/gator/driver/gator_backtrace.c:64:33: error: 'struct module' has no member named 'module_core'
(unsigned long)mod->module_core;
/home/emel/arm-project/gator/driver/gator_backtrace.c: In function 'kernel_backtrace':
/home/emel/arm-project/gator/driver/gator_backtrace.c:105:21: warning: passing argument 1 of 'walk_stackframe' from incompatible pointer type
error, forbidden warning:gator_backtrace.c:105
walk_stackframe(&frame, report_trace, &depth);
In file included from /home/emel/arm-project/gator/driver/gator_backtrace.c:34:0,
./arch/arm64/include/asm/stacktrace.h:31:13: note: expected 'struct task_struct *' but argument is of type 'struct stackframe *'
extern void walk_stackframe(struct task_struct *tsk, struct stackframe *frame,
/home/emel/arm-project/gator/driver/gator_backtrace.c:105:29: warning: passing argument 2 of 'walk_stackframe' from incompatible pointer type
./arch/arm64/include/asm/stacktrace.h:31:13: note: expected 'struct stackframe *' but argument is of type 'int (*)(struct stackframe *, void *)'
/home/emel/arm-project/gator/driver/gator_backtrace.c:105:43: warning: passing argument 3 of 'walk_stackframe' from incompatible pointer type
./arch/arm64/include/asm/stacktrace.h:31:13: note: expected 'int (*)(struct stackframe *, void *)' but argument is of type 'int *'
/home/emel/arm-project/gator/driver/gator_backtrace.c:105:5: error: too few arguments to function 'walk_stackframe'
./arch/arm64/include/asm/stacktrace.h:31:13: note: declared here
scripts/Makefile.build:277: recipe for target '/home/emel/arm-project/gator/driver/gator_main.o' failed
make[1]: *** [/home/emel/arm-project/gator/driver/gator_main.o] Error 1
Makefile:1474: recipe for target '_module_/home/emel/arm-project/gator/driver' failed
make: *** [_module_/home/emel/arm-project/gator/driver] Error 2
make: Leaving directory '/home/emel/arm-project/linux-kernel/kernel'
I read source code gator_backtrace.c:
60 if (mod) {
61 cookie = get_cookie(cpu, current, mod->name, false);
62 addr = addr -
63 #if LINUX_VERSION_CODE < KERNEL_VERSION(4, 5, 0)
64 (unsigned long)mod->module_core;
65 #else
66 (unsigned long)mod->core_layout.base;
67 #endif
68 }
69 else {
70 cookie = NO_COOKIE;
71 }
72 #endif
102 #if defined(__aarch64__) && LINUX_VERSION_CODE >= KERNEL_VERSION(4, 5, 0)
103 walk_stackframe(current, &frame, report_trace, &depth);
104 #else
105 walk_stackframe(&frame, report_trace, &depth);
106 #endif
so is it because linux kernel version not match ?
so I change KERNEL_VERSION(4, 5, 0) instead of KERNEL_VERSION(4, 4, 0)
It can make successfully.
after that i copy gator.ko to rk3399 and insmod .but fail.
unknown symbol in module .
dmesg: unknown symbol walk_stackframe(err 0)
so do I make some mistake with my operation above ? shold I change KERNEL_VERSION(4, 5, 0) ? or where is walk_stackframe ?
thanks very much!
  • For the build errors, the Linux kernel header files of the compiling kernel version does NOT match the gator source code version.
    For the execution errors, the Linux kernel header files of the compiling kernel version ( which decides the generated gator,ko version ) does NOT match the rk3399 kernel version.
  • Hi,
    I face exactly the same situation and error. I appreciated it let me know if you could find a solution for this issue?
    Best regards,
    Ehsan
  • Hi,
    But I add gator module code inside driver of rk3399 (Kernel version 4.4) and it gives compile error, which require to modify gator exactly same as what emel did. When I check the header file arch/arm64/include/asm/stacktrace.h in rk3399 kernel (version 4.4) it has 4 inputs not 3 inputs and so reauire to change:
    104 #else
    106 #endif
    to this:
    102 #if defined(__aarch64__) && LINUX_VERSION_CODE >= KERNEL_VERSION(4, 4, 0)
    104 #else
    106 #endif
    To match with the defined function in Linux header! It resolve the compile error but when I try to compile gator module out of the tree, it give warning:
    WARNING: "walk_stackframe" [../gator.ko] undefined.
    And I guess it may not work well or may even not load correctly.
    PS: I am using kernel inside AOSP of Rockpi n10 board:
    https://gitlab.com/rk-vendor/rk/kernel/-/tree/rk3399pro-toybrick-stable
    Best regards,
    Ehsan
