I tried to use gcc from gcc-arm-8.2-2018.08-i686-mingw32-aarch64-elf.tar.xz in Windows 10 but encountered the following problems:
Any suggestions how to get compiling with gcc8 and -mabi=ilp32 working in Windows?
Jyrki
Dear Jyrki,
Thank you for your feedback.
Regarding point 1) Which program/application have you used to extract tar.gz files we've provided ?
Regarding point 2) I will try reproduce and get back to you. Your my_test.cpp is just a plain "hello world" application I presume.
kind regardsPrzemyslaw Wirkus
Thanks for the response.
1) I have been using WinZip version 19.5 to extract the tar.gz files. It works fine for example for gcc-linaro-7.3.1-2018.05-i686-mingw32_aarch64-elf.tar.xz from the Linaro site. Anyway, it took me some time to figure out what my problem was with gcc 8.2 tar.gz and to find a workaround (I'm only a casual user of Linux) so I thought to post my solution here if anyone else would encounter the same problem.
2) The content of my_test.cpp is below. I was also using the -c option for compile only.
int main(){ return 1;}
Regards, Jyrki
Dear Jyrki,I was able to reproduce your "-mabi=ilp32 support" issue. We recognize this as a issue with the toolchain release and we will investigate.
In the mean time please file a bug on https://bugs.linaro.org/ regarding issue #2 (-mabi=ilp32 support) so it can be tracked externally.
Bug report: https://bugs.linaro.org/show_bug.cgi?id=4020
Dear Jyrki,This issue was addressed in GNU Toolchain for the A-profile Architecture Version 8.2-2018.11.kind regardsPrzemyslaw Wirkus
