When trying to compile the following file using arm-none-eabi-gcc-7.3.1 I get a linker error.
inline int test() { return 0; } int main(int argc, char* argv[]) { test(); return 0; }
Command line: arm-none-eabi-gcc.exe test.c --specs=nosys.specs
Output:
ccc547p6.o: In function `main':test.c:(.text+0x14): undefined reference to `test'
Analysis of intermediate assembly output reveals that compiler treats test() function as inline and does not generate a body for it, but then, when it generates a code for main function, it generates a regular, non-inline call to test() function instead of inlining it, which, of course, upsets the linker later.
Probing the compiler for __STDC_VERSION__ reveals that it is set to 201112L, pointing to C11 compliance. Support for inline functions in C mode was introduced in C99, so it should be handled correctly by C11-compliant compiler.
Of course, inline function specifier is merely a hint (according to the standard), so implementations may elect to not inline functions at all, but they can't do it half-way by first not generating a function body, but then calling functions using regular calls - this will lead to inability to link.
By the way, none of this happens in C++ mode, arm-none-eabi-g++ compiles and links the same file without an error.
Am I doing something wrong?
You can fix the error a couple different ways. The first one is to add static.
static inline int test() { return 0; } int main(int argc, char* argv[]) { test(); return 0; }
The second option is to add extern because inline by itself creates external linkage.
extern int test(); inline int test() { return 0; } int main(int argc, char* argv[]) { test(); return 0; }
Thanks,
Jason
