Profiling Android native code
I have tried to profile Android native code from an APK generated by Android Studio, but I cannot work it out.
When I used the capture functionality in Streamline, I cannot see any process but the libgatord.so.
Any idea how to profile my own Android native code in Streamline?
Any feedback would be thankful!
KuoHsin
  • Hello,
    Assuming your device is non-root and you want to profile all the processes in the system I recommend to use the gatord from $DS5_HOME/sw/streamline/bin (either arm or arm64 version depending on your device) and put it on the device into /data/local/tmp
    I work on Ubuntu host so I use:
    $ sudo ./adb push $DS5_HOME/sw/streamline/bin/arm/gatord  /data/local/tmp
    Then shell into the device and start gatord
    $ sudo ./adb shell
    [ now on device ]
    albus:/ $ cd /data/local/tmp
    albus:/data/local/tmp $ ./gator &
    When I do this I can connect Streamline and see all of the processes. If I just install the streamline-daemon-app.apk on the device I just see the gatord process.
    I don't know if this is device specific or not, but give it a try.
    Thanks,
    Jason
  • Thanks Jason, your response helps me a lot.
