Why program switches from thumb to ARM
Note: This was originally posted on 24th November 2011 at http://forums.arm.com
Hi Everyone
I've got beginner question (hope this is right place to do it, if not please direct me). I 've prepared whole environment for my STM32F103VCT6 Cortex-M3 processor using Sourcery G++ Lite, Eclipse and Segger GBD Server. I have problem with debugging, for simplest possible program it is available and working, but for more "complicated" like new function it stops. My compilation flags are:
C_FLAGS := -c -ggdb -mcpu=cortex-m3 -mthumb
my script linker:
MEMORY
   FLASH : ORIGIN = 0x08000000, LENGTH = 256K
   RAM  : ORIGIN = 0x20000000, LENGTH = 48K
SECTIONS
   .text :
      KEEP(*(.interrupt_vector))
      *(.text)
   } > FLASH
   .data :
      _data_begin_ = .;
      *(.data)
      _data_end_ = .;
   } > FLASH
   .bss :
      _bss_begin_ = .;
      *(.bss)
      _bss_end_ = .;
   } > RAM
   _stack_size_ = 1024;
   _stack_end_ = ORIGIN(RAM) + LENGTH(RAM);
   _stack_begin_ = _stack_end_ - _stack_size_;
   ._stack :
      . = . + _stack_size_;
   } > RAM
ENTRY(handler_reset)
my startup code:
extern unsigned long _stack_end_;
typedef void (*interrupt_routine)( void );
void handler_reset( void );
void handler_default( void );
// vector interrupt table
__attribute__ ( ( section( ".interrupt_vector" ) ) )
interrupt_routine routines[] =
(void*) &_stack_end_,
handler_reset,
handler_default,
// ... itd...
main();
while ( 1 )
and my program (working):
int main( void )
int  a = 3;
int  b = 2;
int  c = 3 + 2;
a = c;
while( 1 )
  // infinite loop
return 0;
and my program (no working, added aa() function):
void aa()
int main( void )
int  a = 3;
int  b = 2;
int  c = 3 + 2;
a = c;
aa();
while( 1 )
  // infinite loop
return 0;
I've got message from Segger debugger:
Setting breakpoint @ address 0x08000034, Size = 2, BPHandle = 0x0023
Starting target CPU... WARNING: T-bit of XPSR is 0 but should be 1. Changed to 1. ...Target halted (PC = 0xF04FAF00)
Reading all registers
Removing breakpoint @ address 0x08000034, Size = 2
Does it mean that my program switches from thumb to arm? If so, why it is done?
