Site
Search
User
Site
Search
User
Support forums
Arm Development Studio forum
ARMv6: "invalidate D-cache line" instruction doesn't work?
Jump...
Cancel
Locked
Locked
Replies
Subscribers
118 subscribers
Views
Users
0 members are here
Options
More actions
Cancel
Related
Zhanguo Li
over 12 years ago
Note: This was originally posted on 10th November 2011 at
http://forums.arm.com
I am trying to test the "invalidate D-cache line" instruction of Freescale imx31/35 processor(ARMv6) and seems that it fails to work.
Below are my test pseudocode:
1. pBuf = malloc(xxx) /* alloc a write-back memory */
2. *(volatile char *)pBuf = 0; /* not cache hit now and not write-allocate, so 0 is written to memory */
3. data = *(volatile char *)pBuf; /* read the date to cache */
4. *(char *)pBuf = 0xaa; /* write 0xaa to cache */
5. invalidate pBuf cache line; /* via mcr or mcrr instruction */
6. data = *(volatile char *)pBuf; /* read it again */
7. data should not be 0xaa, otherwise the invalidate instruction does not work.
Note that my real test code are more strict than the pseudocode, and it works well in ARMv7 platform
So is there knowd issue for ARMv6 "invalidate D-cache line" instruction?
Thanks a lot!
-Jerry
Zhanguo Li
over 12 years ago
Note: This was originally posted on 17th November 2011 at
L2 cache is disabled in my platform
Cancel
Vote up
0
Vote down
Cancel
Zhanguo Li
over 12 years ago
Note: This was originally posted on 22nd November 2011 at
Thanks for your reply. ttfn.
Actually I do not need a clean operation here as I just want to test invalidate instructions. And furthermore, DSB has been added in my "invalidate D-cache line" routines.
Cancel
Vote up
0
Vote down
Cancel
Martin Weidmann
over 12 years ago
Note: This was originally posted on 18th November 2011 at
An invalidate causes the contents of the cache to be thrown away. Which means that any dirty data (changes held in the cache, but not yet memory) are lost!
If you want external memory to be updated you need to do a clean (or clean + invalidate).
Other things to consider are barriers. You may need to add a DSB between the cache command and the read/write of the address. This is to ensure that they happen in order. This is a side effect of a loosely ordered memory system.
Cancel
Vote up
0
Vote down
Cancel
Jerry Fan
over 12 years ago
Note: This was originally posted on 16th November 2011 at
Actually, i.MX31/35 use a IP as L2 cache, and it is external cache. MCR command did not affect the L2 cache. So the L2 cache was not invalidated in your case.
Cancel
Vote up
0
Vote down
Cancel
