NEON intrinsics arguments
Note: This was originally posted on 30th August 2011 at http://forums.arm.com
I'm using the return value from an intrinsic as an argument for another one like below:
int16x8_t final_vec = vorrq_s16(vandq_s16(final_mask_vec, bad_vec), vandq_s16(vmvnq_s16(final_mask_vec), good_vec));
Is that a good idea? Is there anything against using this kind of construct?
I guess the temporary vector returned from one of the inner intrinsics calls still has to be "assigned" to a
NEON register(at least that's my feeling the compiler will do). What happens if in a loop I try to optimize
using intrinsics I exceed the number of the actual Q registers NEON has available?
  • Note: This was originally posted on 31st August 2011 at http://forums.arm.com
    Thanks a lot for the explanations and the tip.
  • Note: This was originally posted on 30th August 2011 at http://forums.arm.com
    This approach is fine.
    As you guessed the compiler will still have to create temporary/intermediate values but will reuse the registers without any trouble, so in your example its likely to never use more than 1 additional temp as well as the final register. Something like:
    int16x8_t final_vec = vmvnq_s16(final_mask_vec);
    int16x8_t tmp0 = vandq_s16(final_mask_vec, bad_vec);
    final_vec = vandq_s16(final_vec, good_vec);
    final_vec = vorrq_s16(tmp0, final_vec); // 'tmp0' register available after this
    As with general arm code any values that can't be fitted into the available registers will be put onto the stack.
    I should add that this example can be replaced with the vbslq_s16 intrinsic (indeed the compiler might manage this for you):
    int16x8_t final_vec = vbslq_s16( vreinterpretq_u16_s16( final_mask_vec ), bad_vec, good_vec );
    Simon.
