Fast Model: Best way to model unaligned multiple register read/write
I am looking for a good method to implement multiple unaligned register access using LISA+ in Fast Model. Can you recommend a good way to do this?
For example, below are the register declaration:
REGISTER { reg_number(0x0000), bitwidth(16), reset_value(0x3836) } REG16_000;  //address 0x00
REGISTER { reg_number(0x0002), bitwidth(8),  reset_value(0x1)    } REG8_002;  //address 0x02
REGISTER { reg_number(0x0003), bitwidth(8),  reset_value(0x0)    } REG8_003;  //address 0x03
And in the application we should be able to perform the following:
*((uint16_t *)0x20000000) = 0xAAAA;        //write to REG16_000
*((uint32_t *)0x20000000) = 0xAAAABBCC;     //write to REG16_000, REG8_002, REG8_003
*((uint8_t *)0x20000001) = 0xAA;            //write to second byte of REG16_000 only
I am relatively new to LISA and Fast Model. And all the examples in the shows aligned access to single registers (ie: access to single register at aligned address).
Thanks in advance
  • Are these three fields within one larger register?  If so, you do something like:
    REGISTER { bitwidth(32) } myRegister;
    REGISTER { bitwidth(16), partof(myRegister) } REG8_000;
    REGISTER { bitwidth(8), partof(myRegister), lsb_offset(16) } REG8_002;
    REGISTER { bitwidth(8), partof(myRegister), lsb_offset(24) } REG8_003;
  • Hi,
    I am sorry for the missing information.
    1. They are not part of a bigger register, but individual registers.
    2. In the ASIC implementation, these register is put into a big register file (>128bytes) and they are mixed
    I am thinking of modeling it as a RAMDevice, but I am not sure if it is the best approach.
    Many thanks.
  • You can find an example of how to implement a simple register bank in the SimplePVbusMaster component.
    The access to the register will be done via the device port of the PVBusSlave component, and you can deal with different access sizes at this point with the granularity you need.
    internal slave port<PVDevice> device
        behavior read(pv::ReadTransaction tx):pv::Tx_Result
        // implement the desired register read accesses here
        // treating your registers as normal variables
    I hope that helps,
    Simon
