I've read everything I could put my hands on to figure this out but have had no luck. I installed the win32 exe gcc-arm-none-eabi-6-2017-q2-update-win32-sha2.exe but it is not found by Eclipse. I know it says to leave the environment variable blank but I even tried that without success. On Eclipse in the list of available toolchains it just does not show. Any ideas why?
Hi markwaldin,
I have moved your question to the Software Tools community as they should be able to help you on this.
ThanksRyan
Just to confirm: Have you looked at the "Adding New Compiler Toolchains to DS-5" tutorial atdeveloper.arm.com/.../adding-new-compiler-toolchains-to-ds-5
