Streamline Community Edition Mali Counters
Hi there,
I am using the Community Edition of Streamline and am connecting to an EXYNOS5422 with a ARM Mail-T628 on board.
I'm trying to view the Mali counters for the GPU, but I cannot see the option in my Streamline counter configuration. When I try to add the Mali Midgard via "Add counters from a template", it says that my target does not support them.
Can I get some information on which configs I should be turning on? I suppose I may have missed something, but I turned on :
~$ zcat /proc/config.gz | grep MALI
CONFIG_MALI_MIDGARD=y
# CONFIG_MALI_TIMELINE_DISABLED is not set
CONFIG_MALI_GATOR_SUPPORT=y
# CONFIG_MALI_MIPE_ENABLED is not set
CONFIG_MALI_MIDGARD_DVFS=y
CONFIG_MALI_MIDGARD_ENABLE_TRACE=y
# CONFIG_MALI_DEVFREQ is not set
CONFIG_MALI_EXPERT=y
# CONFIG_MALI_DEBUG_SHADER_SPLIT_FS is not set
CONFIG_MALI_PLATFORM_FAKE=y
# CONFIG_MALI_PLATFORM_DEVICETREE is not set
CONFIG_MALI_PLATFORM_THIRDPARTY=y
CONFIG_MALI_PLATFORM_THIRDPARTY_NAME="5422"
# CONFIG_MALI_DEBUG is not set
# CONFIG_MALI_NO_MALI is not set
# CONFIG_MALI_TRACE_TIMELINE is not set
# CONFIG_MALI_SYSTEM_TRACE is not set
# CONFIG_MALI_GPU_TRACEPOINTS is not set
Should I try turning on all of the configs for Mali?
  • Hi Prateekmohan,
    There can be a few reasons why you don't get any Mali counters on your device. Firstly, are you building the gator.ko with the correct options? When building the gator.ko you need to specify the following build time options.
    GATOR_WITH_MALI_SUPPORT=MALI_MIDGARD DDK_DIR=".../path/to/Mali_DDK_kernel_files"
    So in a typical kernel that has Mali integrated you can find your Mali_DDK_kernel_files in drivers/gpu/arm/...
    For gator to work you also need to build your kernel with the option CONFIG_MALI_GATOR_SUPPORT=y from the list you wrote in your reply. None of the other configs should be important.
    There is a lot of information for building gator and the Mali driver for profiling provided in the documentation for Streamline which can be found at sw/streamline/gator/README.md
    If none of the suggestions above work could you give me some more information about your device:
    .) The device you are using is it a development board or a production device?
    .) What version of the Mali Driver are you using?
    .) What version of the Linux kernel are you using?
    .) If known what build options are used to build the Mali driver.
    Hope this helps,
    Stephen
  • Hey Stephen,
    Thanks for the detailed answer - maybe I am not building the gator.ko correctly.
    On the Github page (GitHub - ARM-software/gator) the steps to build the gator.ko is just
    "make -C <kernel_build_dir> M=`pwd` ARCH=arm CROSS_COMPILE=<...> modules"
    It doesn't really mention anything about the build time option you described (ie. "GATOR_WITH_MALI_SUPPORT=MALI_MIDGARD DDK_DIR=".../path/to/Mali_DDK_kernel_files"). Can you explain that to me again? Perhaps that is why it is not working.
    I'm also wondering about this line on the Github page :
    "cp -r /path/to/streamline/gator/driver ."
    Is this copying the directory for the gator driver from my streamline installation (ie. for me, I installed it in "/usr/local/DS-5_CE_v5.25.0/sw/streamline/gator/driver"). Am I making the gator.ko from copying this directory? I'm asking because what I did was I downloaded the source from the Github page, went into the "drivers" directory from that and built it from there.
    And finally, just in case it helps:
    1) I'm using an Odroid XU4 board - it has a Mali T628 on it.
    2) On the Odroid XU4 board, my Driver is "EGL_VERSION = 1.4 Midgard-"r9p0-05rel0"
    3) The linux kernel is 3.10.96+
    4) This is what I'm not entirely sure about then. I built the gator.ko using the instructions in the Github page.
    Thanks Stephen!
  • Hey Peter, I looked at the link and realize I didn't do the "insmod"
    However, even after I did, when I do an "ls /dev/gator" I get a Not Found. Do you know why that might be happening?
  • <<<<<<driver/gator_trace_gpu.c:22:36: fatal error: linux/mali_linux_trace.h
    This error is due to the difference between old and new DDK version
    You need to use :
    MALI_DIR_MIDGARD="your_kernel_directory/drivers/gpu/arm/midgard",  not DDK_DIR="your_kernel_directory/drivers/gpu/arm/midgard" to build your gator.ko
    Cheers
  • I think I'm building the gator module incorrectly.
    Whenever I try to do the make command, it mentions that it cannot find certain '.c' or '.h' files but they are in the GPU kernel driver directory. For example, I had this error:
    /home/prateekmohan/EEE598/gator/gator/driver/gator_events_mali_midgard_hw.c:30:41: fatal error: kbase/src/common/mali_kbase.h: No such file or directory
    To fix these, I manually copied over the '.c' and '.h' files from my kernel directory to the gator driver directory (the gator driver directory is where I issued the make command).
    Now, I'm getting these errors below and I'm not entirely sure why:
    prateekmohan@prateekmohan-HP-15-Notebook-PC:~/EEE598/gator/gator/driver$ make -C /home/prateekmohan/EEE598/build/ M=`pwd` ARCH=arm CROSS_COMPILE=arm-eabi- GATOR_WITH_MALI_SUPPORT=MALI_MIDGARD KCFLAGS="-I/home/prateekmohan/EEE598/odroid-kernel/drivers/gpu/arm/midgard/" DDK_DIR="/home/prateekmohan/EEE598/odroid-kernel/drivers/gpu/arm/midgard/" modules
    make: Entering directory `/home/prateekmohan/EEE598/build'
      CHK     /home/prateekmohan/EEE598/gator/gator/driver/gator_src_md5.h
      CC [M]  /home/prateekmohan/EEE598/gator/gator/driver/gator_main.o
      CC [M]  /home/prateekmohan/EEE598/gator/gator/driver/gator_events_mali_midgard_hw.o
    /home/prateekmohan/EEE598/gator/gator/driver/gator_events_mali_midgard_hw.c:71:20: error: expected declaration specifiers or '...' before '*' token
    /home/prateekmohan/EEE598/gator/gator/driver/gator_events_mali_midgard_hw.c:72:20: error: expected declaration specifiers or '...' before '*' token
    /home/prateekmohan/EEE598/gator/gator/driver/gator_events_mali_midgard_hw.c:73:20: error: expected declaration specifiers or '...' before '*' token
    /home/prateekmohan/EEE598/gator/gator/driver/gator_events_mali_midgard_hw.c:74:20: error: expected declaration specifiers or '...' before '*' token
    /home/prateekmohan/EEE598/gator/gator/driver/gator_events_mali_midgard_hw.c:75:19: error: expected declaration specifiers or '...' before '*' token
    /home/prateekmohan/EEE598/gator/gator/driver/gator_events_mali_midgard_hw.c: In function 'init_symbols':
    /home/prateekmohan/EEE598/gator/gator/driver/gator_events_mali_midgard_hw.c:483:5: warning: assignment from incompatible pointer type [enabled by default]
    /home/prateekmohan/EEE598/gator/gator/driver/gator_events_mali_midgard_hw.c:484:5: warning: assignment from incompatible pointer type [enabled by default]
    /home/prateekmohan/EEE598/gator/gator/driver/gator_events_mali_midgard_hw.c:485:1: error: 'kbase_instr_hwcnt_enable_symbol' undeclared (first use in this function)
    /home/prateekmohan/EEE598/gator/gator/driver/gator_events_mali_midgard_hw.c:485:1: note: each undeclared identifier is reported only once for each function it appears in
    /home/prateekmohan/EEE598/gator/gator/driver/gator_events_mali_midgard_hw.c:486:1: error: 'kbase_instr_hwcnt_clear_symbol' undeclared (first use in this function)
    /home/prateekmohan/EEE598/gator/gator/driver/gator_events_mali_midgard_hw.c:487:1: error: 'kbase_instr_hwcnt_dump_irq_symbol' undeclared (first use in this function)
    /home/prateekmohan/EEE598/gator/gator/driver/gator_events_mali_midgard_hw.c:487:5: error: 'kbase_instr_hwcnt_dump_irq' undeclared (first use in this function)
    /home/prateekmohan/EEE598/gator/gator/driver/gator_events_mali_midgard_hw.c:488:1: error: 'kbase_instr_hwcnt_dump_complete_symbol' undeclared (first use in this function)
    /home/prateekmohan/EEE598/gator/gator/driver/gator_events_mali_midgard_hw.c:489:1: error: 'kbase_instr_hwcnt_disable_symbol' undeclared (first use in this function)
    /home/prateekmohan/EEE598/gator/gator/driver/gator_events_mali_midgard_hw.c:490:5: warning: assignment from incompatible pointer type [enabled by default]
    /home/prateekmohan/EEE598/gator/gator/driver/gator_events_mali_midgard_hw.c: In function 'clean_symbols':
    /home/prateekmohan/EEE598/gator/gator/driver/gator_events_mali_midgard_hw.c:511:1: error: 'kbase_instr_hwcnt_enable_symbol' undeclared (first use in this function)
    /home/prateekmohan/EEE598/gator/gator/driver/gator_events_mali_midgard_hw.c:512:1: error: 'kbase_instr_hwcnt_clear_symbol' undeclared (first use in this function)
    /home/prateekmohan/EEE598/gator/gator/driver/gator_events_mali_midgard_hw.c:513:1: error: 'kbase_instr_hwcnt_dump_irq_symbol' undeclared (first use in this function)
    /home/prateekmohan/EEE598/gator/gator/driver/gator_events_mali_midgard_hw.c:514:1: error: 'kbase_instr_hwcnt_dump_complete_symbol' undeclared (first use in this function)
    /home/prateekmohan/EEE598/gator/gator/driver/gator_events_mali_midgard_hw.c:515:1: error: 'kbase_instr_hwcnt_disable_symbol' undeclared (first use in this function)
    /home/prateekmohan/EEE598/gator/gator/driver/gator_events_mali_midgard_hw.c: In function 'start':
    /home/prateekmohan/EEE598/gator/gator/driver/gator_events_mali_midgard_hw.c:527:5: error: unknown type name 'mali_error'
    /home/prateekmohan/EEE598/gator/gator/driver/gator_events_mali_midgard_hw.c:613:34: error: 'struct kbase_device' has no member named 'shader_present_bitmap'
    /home/prateekmohan/EEE598/gator/gator/driver/gator_events_mali_midgard_hw.c:641:14: error: 'struct kbase_uk_hwcnt_setup' has no member named 'l3_cache_bm'
    /home/prateekmohan/EEE598/gator/gator/driver/gator_events_mali_midgard_hw.c:644:9: error: implicit declaration of function 'kbase_instr_hwcnt_enable_symbol' [-Werror=implicit-function-declaration]
    /home/prateekmohan/EEE598/gator/gator/driver/gator_events_mali_midgard_hw.c:645:20: error: 'MALI_ERROR_NONE' undeclared (first use in this function)
    /home/prateekmohan/EEE598/gator/gator/driver/gator_events_mali_midgard_hw.c:650:9: error: implicit declaration of function 'kbase_instr_hwcnt_clear_symbol' [-Werror=implicit-function-declaration]
    /home/prateekmohan/EEE598/gator/gator/driver/gator_events_mali_midgard_hw.c: In function 'stop':
    /home/prateekmohan/EEE598/gator/gator/driver/gator_events_mali_midgard_hw.c:712:9: error: implicit declaration of function 'kbase_instr_hwcnt_disable_symbol' [-Werror=implicit-function-declaration]
    /home/prateekmohan/EEE598/gator/gator/driver/gator_events_mali_midgard_hw.c: In function 'read':
    /home/prateekmohan/EEE598/gator/gator/driver/gator_events_mali_midgard_hw.c:833:5: error: implicit declaration of function 'kbase_instr_hwcnt_dump_complete_symbol' [-Werror=implicit-function-declaration]
    /home/prateekmohan/EEE598/gator/gator/driver/gator_events_mali_midgard_hw.c:866:9: error: implicit declaration of function 'kbase_instr_hwcnt_dump_irq_symbol' [-Werror=implicit-function-declaration]
    cc1: some warnings being treated as errors
    make[3]: *** [/home/prateekmohan/EEE598/gator/gator/driver/gator_events_mali_midgard_hw.o] Error 1
    make[2]: *** [_module_/home/prateekmohan/EEE598/gator/gator/driver] Error 2
    make[1]: *** [sub-make] Error 2
    make: *** [all] Error 2
    make: Leaving directory `/home/prateekmohan/EEE598/build'
  • Thanks dynamic, I tried that but I got the same error as I posted below. Another thing I'm wondering is what the <kernel_build_dir> is in the command
    Does this refer to the directory of the kernel source? Or the directory of the built kernel (ie. the directory with the boot images, etc..)?
    I'm asking because when I use the kernel source directory, I get the error below. If I run it using the built kernel directory, I get my previous error (the error shown below where I used 'MALI_DIR_MIDGARD' instead of 'DDK_DIR' ). Some things successfully build but it fails when it gets to gator_events_mali_midgard_hw.o.
    ERROR if running the make command in the kernel source.
      ERROR: Kernel configuration is invalid.
             include/generated/autoconf.h or include/config/auto.conf are missing.
             Run 'make oldconfig && make prepare' on kernel src to fix it.
      WARNING: Symbol version dump /home/prateekmohan/EEE598/odroid-kernel/Module.symvers
               is missing; modules will have no dependencies and modversions.
      Building modules, stage 2.
    /home/prateekmohan/EEE598/odroid-kernel/scripts/Makefile.modpost:42: include/config/auto.conf: No such file or directory
    make[1]: *** No rule to make target `include/config/auto.conf'.  Stop.
    make: *** [modules] Error 2
    make: Leaving directory `/home/prateekmohan/EEE598/odroid-kernel'
    ERROR after using 'MALI_DIR_MIDGARD' instead of 'DDK_DIR':
    prateekmohan@prateekmohan-HP-15-Notebook-PC:~/EEE598/gator/gator/driver$ make -C /home/prateekmohan/EEE598/build/ M=`pwd` ARCH=arm CROSS_COMPILE=arm-eabi- GATOR_WITH_MALI_SUPPORT=MALI_MIDGARD KCFLAGS="-I/home/prateekmohan/EEE598/odroid-kernel/drivers/gpu/arm/midgard/" MALI_DIR_MIDGARD="/home/prateekmohan/EEE598/odroid-kernel/drivers/gpu/arm/midgard/" modules
  • Hi Prateekmohan1,
    I will try and answer some of the points you have made:
    "It doesn't really mention anything about the build time option you described (ie. "GATOR_WITH_MALI_SUPPORT=MALI_MIDGARD DDK_DIR=".../path/to/Mali_DDK_kernel_files"). Can you explain that to me again? Perhaps that is why it is not working."
    In the gator github entry there is a file called Readme.md. There should be a seperate section in that readme labelled Mali GPU hopefully that will give you some more information. But Pete is right the Streamline documentation online is also a good source of information.
    "Thanks dynamic, I tried that but I got the same error as I posted below. Another thing I'm wondering is what the <kernel_build_dir> is in the command
    "make -C <kernel_build_dir> M=`pwd` ARCH=arm CROSS_COMPILE=<...> modules""
    Where are you passing the DDK_DIR information have you edited the makefile instead? I wouldn't copy the kernel files over to the directory I would just specify the path just in case anything is missing?
    Are you using the stock hardkernel provided kernel on your OdroidXU4? If you are I can take a quick look and see if there is anything sticks out as to why you would be seeing issues?
    Kind regards,
    Stephen
  • Hi prateekmohan1,
    -----ERROR: Kernel configuration is invalid.
    Have you enabled mali support in your kernel configuration?
  • Thanks for the detailed reply Stephen - appreciate it.
    I in fact got it working, and for others with this problem, I was building my kernel into a different directory than the source. Normally, if you just run the "make" command in the kernel source, it will build it in the same directory. I was building it in a separate directory which was causing issues when gator was being built.
    After you build it in the same directory and the kernel successfully builds the way that I built gator.ko (that worked) was:
    The directory I bolded should be your kernel source directory. Because you have built the kernel in the same directory it has all the files that gator requires to build gator.ko.
    Thanks for all the help guys! Really appreciate it!
