I am trying to program a target CPU (R4) on my FPGA platform and I keep getting the following error:
[ME@MACHINE bin]$ debugger --cdb-root /home/ME/ConfigDb --cdb-entry="COMPANY::BOARD::Bare Metal Debug::Bare Metal Debug::Cortex-R4_0::DSTREAM" --cdb-entry-param "Connection=USB:005012" --image="/home/me/r4_0.axf"
WARNING(TAD16): Failed to disconnect from Cortex-R4
ERROR(TAD3-NAL52):
! Unable to connect to device Cortex-R4_0
! Cannot attain state requested.
When I browse for connections (--browse) I can see that the connection is there for the given cdb entry. As you can guess from the command above, , there are multiple R4s in this design and the result is the same when programming any one of them.
Issuing the same command again, I get the following error:
ERROR(TAD290-DTS77-DTS1-NAL57):
! Failed to connect to platform USB:005012
! Unable to connect to USB:005012
! Unable to connect to device APB_0
! No connection to target.
Then I have to re-download my bitstream to the FPGA board to get back to the original error.
Is there a list of the error codes and what they represent and how to go about fixing them?
Any help is appreciated,
Zeeshan
Hi zeeshan and welcome tot he Connected Community!
I have moved your question to Software Development Tools where I think you will get an answer.
Firstly, please accept my apologies for the delay in getting back to you on this.
As you are connecting to an FPGA, can you just verify that the debugger 'connect-only' option works ok ?
i.e. don't download an .axf, just check that you can connect to the R4 and read registers, memory etc. and so forth.
So try :
and just seeing you can connect and halt the target, step, read regs, memory, etc. etc,
Please let me know how you get on.
Regards,
Stuart
