Hello, all.
I'm trying to attach Dstream JTAG debugger to a Cortex-M3 core on HiKey Board with DS-5 v5.23.0 Ultimate Edition on Windows.
I tried the following procedure but it took more than one minute to connect to the target.
That is too slow to be compared to other platforms (for example, Cortex-A53_SMP on the same HiKey board takes less than 5 seconds to be connected.)
1. Use "Debug Hardware Config" tool to "Auto Configure" and export a platform file. This tool found 8 Cortex-A53 and a Cortex-M3.
2. Use cdbimporter to import the platform file
3. Rebuild the database on DS-5
4. In Debugging perspective, open debugging configuration and select the imported platform -> "Bare Metal Debug" -> "Cortex-M3" and connect to the target
5. More than one minute (about 70 to 100 seconds) later, I cound debug the core.
I also tried the new Eclipse-integrated 'Platform Configuration Editor' (PCE) but the tool could not find the Cortex-M3 core.
Additionally, the configuration for HiKey Board pre-installed in DS-5 also has no Cortex-M3 core.
Does anyone know why it takes so much time (waiting for timeout of something?) and how can I fix it?
