Issue with Debugger Not Connecting in Arm DS
Hi everyone,
I’ve been trying to debug a bare-metal application using Arm Development Studio with a DSTREAM probe, but I keep running into an issue where the debugger won’t connect to the target. The connection just times out, even though the probe is detected correctly.
I’ve double-checked the configuration and the target power is fine. Has anyone run into a similar problem? Are there any lesser-known settings or steps I might be missing in the debug configuration?
Thanks in advance for any suggestions!
https://www.concretesrichmondva.com/
