Server did not shutdown cleanly
We work in Apollo Agilex 7 SOM board and using Ubuntu machine to the target board with onboard JTAG debugger. Currently using Arm Development Studio IDE with 30-day Gold Edition evaluation license for connection between the host computer and board.
The problem is while debugging the code,Agilex development board responds in random manner.Some times debugging process successful,but maximum of time Arm Development Studio fails to connect with target and shows error as following:
1
Starting debug server
Waiting for debug server to start accepting connections
Debug server started successfully
Debug server shutdown application
Debug server does not appear to be running
Done
Server did not shutdown cleanly, killing
2
Failed to read 4 bytes from adderss EL3:0x00000000FFE00000
