Hi Experts,
Does arm eabi gnu-linux supports the compilation for v8 architecture (both baremetal and application) or specific gcc tools needs to be used for the cross compilation ?
Regards,
Techguyz
You will need an AArch64 cross compiler for ARMv8-A AArch64 Linux applications and baremetal code.
Linaro host the required sources for GCC here, or you can download their prebuilt binaries: aarch64-linux-gnu (for Linux apps) | aarch64-elf (for bare-metal)
(Note that the 'aarch64-elf' cross compiler is named 'aarch64-none-elf' in the documentation).
I hope that helps.
Hello Ash,
it looks like all compilers are big endian.
Is the big endian standard for AArch64?
Best regards,
Yasuhiko Koumoto.
The compilers I linked are little-endian (at least, they should be).
See this page for a list of all cross compilers hosted by Linaro. The ones with 'be' in the names are the big-endian ones, whereas the ones I linked were little-endian.
Ash.
