I am trying to use `trace report` command in armdbg to export ITM data. (From armds 2023.0 installation)
I tried:
trace report SOURCE=CSITM_0 FILE=TRACE_ITM.txt DECODERS=P0:Text PORTS=0
TRACE_ITM.txt contents:
UNKNOWN (101 bytes)
When I try the same thing in the armds GUI (using same DTSL, same elf file and almsot quite similar debug steps), with the following event viewer setting I get UNKOWN (108 bytes).
Now if I activate the show live decode console checkbox, and do a "debug from entry point" and run and halt, I can see my printf being shown on the Live Decode console but Events console still shows same message, just maybe with a different size.
Obviously trace report in armdbg generates Events Console like output and that's why I can't rely on Live Decode.
Regards
Amir
+Update:
Getting same behavior with 2024.0
Hi AmirSorry, I can't immediately identify the cause of your problem.Please could you tell us which Cortex-M processor you are using?If your company has purchased a DSTREAM and Arm DS 2024.0 from Arm, then it is probably best for you to log an official support ticket with Arm Support, so that the Arm Support Team can investigate more fully. Select from the top of this page : Support > Arm Support Services, then Open a Support Case.Stephen
Hi Stephen,Thank you for your response.
I am using a custom platform implementing SSE-200 M33 cores (SoC-400). One other observation is that if I put my hello world printf inside a infinite while loop, I can see it being printed in the Events Consol. Alongside some OVERFLOW messages. Which tells me that my data transfer rate is slow! But still I don't understand why something is showing up in the Live Decode and not in the Events.
Sure, I will raise a ticket there.
