I'm using Arm Development Studio Gold Edition 2022.2I was using the "fromelf" utility with "--bin" option (for a plain binary) to convert a given .axf file into .bin file.
However i would like to know with your help how to convert my .axf or.bin file into a binary that only includes 0 & 1 digits?Something like "hex2bin" utility, that convert hex digits into binary digits?
Thanks,
Ronen
Hi RonenI'm not aware of any Arm-provided tool that can do this. If hex2bin works for you then I suggest you use that.Perhaps I've misunderstood, but the picture you gave doesn't seem to show the correct conversion, e.g. the first hex digit '4' should be transformed into binary digits '0','1','0','0', not '1','1','0','1' ?Can you explain why you want to do this? Surely the resulting file will be 8-times larger than the original...Stephen
Hi Stephen,Thanks for your reply.
I admit the picture i gave was not much helped.I meant for the data on the right side, pls see below picture
This requirement arrived from a third party which i'm working with (TSMC).BR,Ronen
Thanks for the pictorial clarification :)As I wrote before, I'm not aware of any Arm-provided tool that can do this.It should be straightforward for you to write some simple C code or Python script to read bytes from the file, perform the conversion, and write the 0s & 1s to an output file.Stephen
