Development Station 2022. I have ITM capture enabled in my debug configuration. In the event window I see no sources in the drop down for adding sources.
What does DS look for to determine the available ITM input sources?
Nevermind, I had forgotten to select a capture method
Is it possible to know the target profile and so it depends on the target supports ITM trace.
