with assembly declear:
#ifdef STANDALONE #define USE_SERIAL_PORT 1 asm(".global __use_no_semihosting"); #endif
to exclude any c clib being linked to output file
but i get the error info as follows:
Error: L6915E: Library reports error: __use_no_semihosting was requested, but _sys_command_string was referenced.
the question is, target is aarch64 cortex-a53,
no choice for me to link micro lib
what should I do?
HiMy name is Stephen and I work at Arm.The error messageError: L6915E: Library reports error: __use_no_semihosting was requested, but _sys_command_string was referenced.is saying you requested no semihosting functions may be linked-in from the C libraries, but _sys_command_string (which uses semihosting) was referenced.You will need to either add your own retargeted version of _sys_command_string into retarget.c, or remove the use of argv and argc to pass parameters to main(). See:developer.arm.com/.../-sys-command-string--Hope this helpsStephen
with the case you recommend,
i add some folder to extend its func,
and modified the makefile in the top folder,
before:
APP_C_SRC := $(wildcard $(SRC_DIR)/*.c) \APP_S_SRC := $(wildcard $(ASM_DIR)/*.S)OBJ_FILES := $(APP_C_SRC:$(SRC_DIR)/%.c=$(OBJ_DIR)/%.o) \ $(APP_S_SRC:$(ASM_DIR)/%.S=$(OBJ_DIR)/%.o)DEP_FILES := $(OBJ_FILES:%=%.d)
after:
$(wildcard $(SRC_DIR)/dirx/*.c) APP_S_SRC := $(wildcard $(ASM_DIR)/*.S)OBJ_FILES := $(APP_C_SRC:$(SRC_DIR)/%.c=$(OBJ_DIR)/%.o) \
$(APP_C_SRC:$(SRC_DIR)/dirx/%.c=$(OBJ_DIR)/%.o)$(APP_S_SRC:$(ASM_DIR)/%.S=$(OBJ_DIR)/%.o)DEP_FILES := $(OBJ_FILES:%=%.d)
but it seemed to be not useful,
the compile output is the same:
12:25:54 **** Build of configuration Default for project startup_Armv8-Ax1_AC6_lab' ****make all mkdir objCompiling src/GICv3_gicd.c...Compiling src/timer_interrupts.c...Compiling src/sp804_timer.c...Compiling src/main.c...Compiling src/GICv3_gicr.c...Compiling src/uart.c...Compiling src/retarget.c...Compiling asm/vectors.S...Compiling asm/v8_aarch64.S...Compiling asm/v8_utils.S...Compiling asm/startup.S...Linking startup_Armv8-Ax1_AC6.axfDone.
12:25:56 Build Finished. 0 errors, 0 warnings. (took 2s.237ms)
no new fiels related information anyway
is there anything i missed?
Hi againTry this instead. Into both makefiles for startup_Armv8-Ax1_AC6 and startup_Cortex-A53x1_AC6 add:APP_C_SRC := $(wildcard $(SRC_DIR)/*.c)EXT_C_SRC := $(wildcard $(SRC_DIR)/dirx/*.c)APP_S_SRC := $(wildcard $(ASM_DIR)/*.S)OBJ_FILES := $(APP_C_SRC:$(SRC_DIR)/%.c=$(OBJ_DIR)/%.o) \ $(EXT_C_SRC:$(SRC_DIR)/dirx/%.c=$(OBJ_DIR)/%.o) \ $(APP_S_SRC:$(ASM_DIR)/%.S=$(OBJ_DIR)/%.o)DEP_FILES := $(OBJ_FILES:%=%.d)and later add a compilation rule for the new folder, for startup_Armv8-Ax1_AC6:$(OBJ_DIR)/%.o : $(SRC_DIR)/dirx/%.c | $(OBJ_DIR) $(PROGRESS) $(QUIET) $(CC) -c $(TARGET_ARCH) $(CPPFLAGS) $(CFLAGS) -o $@ $<and (slightly different) for startup_Cortex-A53x1_AC6:$(OBJ_DIR)/%.o : $(SRC_DIR)/dirx/%.c | $(OBJ_DIR) $(PROGRESS) $(QUIET) $(CC) -c $(TARGET_CPU) $(CPPFLAGS) $(CFLAGS) -o $@ $<Hope this helpsStephen
