I have an MDK-Proffesional License and have been using Keil uvision for development.
As part of evaluating the ARM-DS 2023.0 studio, I changed the compiler to my Arm Compiler for Embedded FuSa 6.16.2.
Then, I used the 'Import of a Keil project'. And received this error upon compilation:
armclang: error: CT.CompilerEM616 is not available with the current toolkit edition and license.
This is the screen shot of the error:
From the error message, it is picking up an evaluation license for Arm Development Studio, which does not enable the FuSa compiler.
Does File > License Management show that it is using the MDK Professional License? You may need to (re) enable it there.
Alternatively, undefine the environment variable ARM_PRODUCT_DEF (and restart uVision IDE).
