How to define a macro function
hi,
    I want to ask a question.
     How to define a macro function that can be called by C language in armasm?
     I know that in GNU can be used in the following way:
.macro push_x1_x12
push x1,x2
push x3,x4
push x5,x6
push x7,x8
push x9,x10
push x11,x12
.endm
ENTRY(test)
push_x1_x12
ENDPROC(test)
  Now  in armasm, I used as follow :
MACRO
push_x1_x12
push x1,x2
push x3,x4
push x5,x6
push x7,x8
push x9,x10
push x11,x12
MEND
But how to expand the macro that can be called by C language??
  • In C language, you can define macros using the #DEFINE pre-processing command.
    It will do text replacement before compiling.
    Here is a documentation chapter explaining ARM Inline Assembly: ARM® Compiler armcc User Guide
    Here is documentation about C preprocessor and #DEFINE: C preprocessor - Wikipedia, the free encyclopedia
    #DEFINE push_x1_x12 \
        __asm {                 \
        push x1,x2              \
        push x3,x4              \
        push x5,x6              \
        push x7,x8              \
        push x9,x10             \
        push x11,x12            \
  • thanks,
    1、I used ARMV8 that platforms is: ARM DS-5 Documentation > ARM Compiler 6 (64-bit platforms only) > armclang Reference Guide
         not armcc but armclang
    2、how to expand in C language?like this:
    void test_tt(void)
          push_x1_x12;
    3、If I want to define a macro with parameters, how to deal with it ?
    Replace:
    .macro cpus_tst_get_opcode, _reg0
    lsl \_reg0,\_reg0,#4
    lsr \_reg0,\_reg0,#24
    .endm
    albanrampon
  • 2. Yes. The #define is identical to replacing the text.
    3. You use parameters like for a function:
    #define RADTODEG(x) ((x) * 57.29578)
    and in your code
    y = RADTODEG(25);
    will do:
    y = (25) * 57.29578;
  • sorry,
    //    define:
    #define  push_x1_x12     \
        __asm {                 \
         push x1,x2              \
         push x3,x4              \
         push x5,x6              \
         push x7,x8              \
         push x9,x10             \
         push x11,x12            \
    //     call
    void test_tt(void)
    push_x1_x12;
    ARM Compiler 6  Compilation error
    javascript:liveAction('org.eclipse.help.ui', 'org.eclipse.help.ui.internal.ShowInTocAction', '2_4')
  • Oups, can you try the following?
    #DEFINE push_x1_x12 __asm("push x1,x2", "push x1,x2", "push x3,x4", "push x5,x6", "push x7,x8", "push x9,x10", "push x11,x12")
    6.4 Inline assembly language syntax with the __asm keyword in C and C++
  • The link just above also shows how to add parameters: you need to put them outside of the " " starting with #.
    There are several ways of declaring assembly instructions. One at a time, or a list. And for the list, the way I explained previously with curly brackets "{}" or like strings in round brackets "()".
    I am not sure why the curly brackets didn't work. It may depend on the compiler.
  • As i can see, the chinese climat make you more productive Alban
  • Macros tend to make things difficult to debug, so if you can I would try to use a normal function and get the compiler to inline it. I try to avoid macros whenever possible; modern compilers are good enough that you can generally avoid them without a performance penalty.
    HTH,
    Pete
  • albanrampon  @Peter Harris
    hi all,
        I need to do some big test cases with macros.
        read armclang's embedded assembly document.    and i can define macros in c ,and expand in c function .
        Now,I want to expand macros in other macros,the code as following:
    //define
    #define cpus_tst_code_lsl(_reg0,ret)  asm("adr  %[input_i],#4\n\t"      \
                "mov %[input_i],%[input_i]\n\t"    \
                "ldr %[input_i],[%[input_i]]\n\t"    \
                "lsl %[input_i],%[input_i],#36\n\t"  \
                "lsr %[input_i],%[input_i],#56\n\t"  \
                "cmp %[input_i],#0x80\n\t"    \
                "b.eq  lable1\n\t"      \
                "mov %[result],#0x1\n\t"      \
                "b lable2\n\t"        \
                "lable1:mov %[result],#0x0\n\t"    \
                "lable2:\n\t"        \
                : [result] "=r"  (ret)      \
                : [input_i] "r"  (_reg0)      \
    //expand
    #define test_cpus_l1_code_base(ret)    asm("mov x5,#16\n\t"        \
                    "mov x6,x4\n\t"        \
                    "mov x8,#20\n\t"        \
                   "cpus_tst_code_lsl x5,%[result] \n\t"    \
    ARM Complier 6Complier  error:
        error: invalid instruction
    <inline asm>:4:2: note: instantiated into assembly here
            cpus_tst_code_lsl x5,x1
  • As described in the suggested by albanrampon to link section 6.4 Inline assembly language syntax with the __asm keyword in C and C++, the correct syntax is:
    //   define:
    __asm {                 \
        "push x1,x2   \n"   \
        "push x3,x4   \n"   \
        "push x5,x6   \n"   \
        "push x7,x8   \n"   \
        "push x9,x10  \n"   \
        "push x11,x12 \n"   \
    //call
    void test_tt(void)
    push_x1_x12;
    See lacked the quotes involving the mnemonics and the line break.
  • Sure. The #define does text replacement only. It does not do any evaluation of your string to then go to look for other things.
