ArmDS build platform fail.
in arm ds environment, build/clean platform report failed,  i can't find anyway to solve this problem through restart armds/create new database and platform.
This environment has been good, i'm not sure when it started to go wrong.
best regard.
thank you.
  • Hi
    My name is Stephen and I work at Arm.
    I believe the issue you are seeing is caused by the path you have specified to the ExtensionDB.  The subfolder names after the "ExtensionDB" folder are not needed.
    In Window > Preferences > Arm DS > Configuration Database
    please change
    C:\Users\cdns-edk\Development Studio Workspace\ExtensionDB\Boards\jm\corsicaall
    to just
    then Rebuild.
    Hope this helps
    Stephen
  • Hi Stephen,
    The problem is solved according to your method.
    Thank you very much!
    Best Regard.
    Thanks.
