I am using ARM DS and the Altera USB-II Blaster to connect to my Cyclone V target board.
When I first connect, I am getting the following error:
ERROR(CMD463): # in preloader.ds:12 while executing: reset system! The reset capability system is not availableERROR(CMD656): The script preloader.ds failed to complete due to an error during execution of the script
My board still connects but does not reset the SW on connection, however, I am able to step through my program with the debugger.
I ran the info capabilities command which returned this section for Reset options (no SW options):
Reset options Hardware Reset Available while running=true [Indicates whether System reset is available while running]
What options do I have to restart the SW on connection instead of jumping in at the current point of execution?
Hello, you will likely get a more focused audience for your query on the Intel forum:https://community.intel.com/t5/Intel-SoC-FPGA-Embedded/bd-p/soc-fpga-embedded-development-suite
