Error Installing Pack: File not found or not accessible
I recently installed Arm DS 2023.0 and am running through the Getting started with Cortex-M using Arm DS and CMSIS guide.
When I first open up using the CMSIS-Pack Manager, then attempting to install any pack, I get the following console output
javax.net.ssl.SSLHandshakeException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
Pack updates are completed
09:49:42: Processing completed
09:49:48: Installing Pack ARM.CMSIS.5.9.0 was not successful: File not found or not accessible: http://www.keil.com/pack/ARM.CMSIS.5.9.0.pack
This appears to be a new problem as last Friday (5/5/2023) I was able to install the CMSIS pack without issue.
  • Hi
    My name is Stephen and I work at Arm.
    Sorry that you've hit this problem.  Unfortunately, I can't reproduce what you see.  I just tried installing ARM.CMSIS.5.9.0 into Arm DS 2023.0 and saw:
    16:35:11: Processing completed
    16:38:08: Installing Pack ARM.CMSIS.5.9.0 completed
    I'm checking with colleagues on whether there is any further explanation.
    Stephen
